I need a little help
I am ready to start my rebuilt car, but still have a couple of outstanding issues.
The gas pedal which should be mounted to the floor along w/ the other two pedals on my fiberfab falls directly to the floor instead of pushing the bar and original setup back. It seems I cannot remember how that worked when I took the car apart 5 years ago. It needs it to push the bar back and not down. What am I missing?
Also the new master cyl that was waiting in a box for 1 1/2 years is leaking at one of the rubber plugs ( where the hoses hook up ) when I try to bleed the brakes. Is it possible that it is not installed correctly or came loose when I pushed on the hose from the brake fluid container? I called a VW place and they said it my have dried out while in the box, but it does not look cracked etc.
Anyway thanks for any help, Dale
