Having a problem with venting. rubber hose is clear, but very thin and difficule to blow air through. It leaves vent pipe, at filler neck and goes stright down to hole in pan but gas backs up through cap, and vapor does not exit vent. What diameter hose should I use and what is routing. Early fiberfab Migi with stock 67 tank. Thanks, Dennis P
