New Old MGTD Project
Home Forums MGTD Kit Cars My Project New Old MGTD Project
This topic contains 1 reply, has 2 voices, and was last updated by  billnparts 6 years, 11 months ago.
  • #234534
    flipmgtd
    @flipmgtd
    New member taking over a 26 year old MGTD Ford kit that was never really started.  Appreciate all the help and advice I can get as I work through this build.  Missing a few parts, most important right now are the radiator brackets.  Any ideas where I can source these?
    #254585
    billnparts
    @billnparts
    The radiator mounting brackets can be easily made from three small pieces of angle. The frame rails should be drilled and tapped from the factory. Instructions for cutting the factory mounting flange from the radiator and using the fan shroud mounting holes can be found in the manuals in the sidebar on the left side of this forum. Its a difficult location to photograph, but luckily mine is somewhat apart. If you can make this out, good.
    "Drive Happy"
You must be logged in to reply to this topic.
Skip to toolbar
