white warning light went on
Home Forums MGTD Kit Cars VW Based Kits white warning light went on
This topic contains 3 replies, has 3 voices, and was last updated by  bgtrn 3 years, 9 months ago.
  • #235243
    bgtrn
    @bgtrn
    Started vw/td after hour sitting and a white light went on on thr right of the signal indicator, on speedo.  Went off in about 30 seconds, not happened again or before, oil fresh and full.  Any ideas????
    #260703
    royal
    @royal
    White (?) Warning light?
    #260704
    kentt
    @kentt
    The warning lights in the speedometer use a thin piece of colored plastic to make them appear green or red — the bulbs behind them are clear/white – so that piece of colored film has likely come loose and fallen off…
    Back to the original question, a delay of a few seconds ifor the oil pressure light to go out s normal
    Anything over about 5 seconds though, would have me looking for the cause…
    It MAY be the pressure relief valve in the rear (pulley end) of the engine sticking…
    #260705
    bgtrn
    @bgtrn
    Thanks, will keep watch.
You must be logged in to reply to this topic.
Skip to toolbar
