Car dying in idle after carb rebuild
Home Forums MGTD Kit Cars VW Based Kits Car dying in idle after carb rebuild
  • This topic has 4 replies, 3 voices, and was last updated 9 years ago by Anay.
  • #236123
    Anay
    @anayb
    Hi guys,
    Anay here with a Solex H30/31 carb, that I did an express clean for (new gaskets etc… It was already in pretty good shape, but after reattaching, idle screw 6 full turns out, the car strangely dies after hang at about 1000 RPMs… Maybe after only 4 minutes. Thoughts?
    Anay
    Happy to chat with anyone if they have a minute, total newbie.
    #268064
    Anay
    @anayb
    May have fixed it… Couldn’t have been the Fast Idle Adjuster? That screw on the throttle that hits the cam? Could that have been the reason? If the screw was way too loose?
    #268065
    Could be. You want to set the idle on a warm engine. Cold fast idle should be like 1400. The Muir book has the procedure. Don’t skip any steps!
    #268066
    greg press
    @greg-press
    There are u tube videos that will get you through anything including carb adjustment fuel pump repair/ replace etc
    #268067
    Anay
    @anayb
    Thanks! Think it was the fast idle adjuster screw! But will check the fuel pump as well 🙂
