Dash center
Home Forums MGTD Kit Cars VW Based Kits Dash center
Viewing 1 post (of 1 total)
  • #232568
    bill lauro
    @deerebill
    Just a few shots so you can see were I am so far. The dash center is abalone shell from Alsa corp. I am  happy with how it turned out and it is easy to work with. Some parts have come in for the wind shield and it is moving right along. I have the seal for the bottom that I will install after the glass and I had to cut down the wiper arms to fit. You can buy them but $70.00 is a bit much. I found a motor for $29.00 that has a switch on the back so it is all coming together.The exhaust is a bit different also and when I lay it out I post a shot or two. Vw and Corvairs have a sound that is very distintive and the reason is the short travel of the exhaust,I am about to change that. Good luck. Bill
