Home › Forums › MGTD Kit Cars › VW Based Kits › Disk Brake Conversion
- This topic has 6 replies, 4 voices, and was last updated 14 years, 11 months ago by
newkitman.
April 21, 2011 at 7:47 am #233442
What disk brake conversion kit do you suggest?
Pat
April 22, 2011 at 12:58 am #244371There seems to be many suppliers offering front disk brake kits and most of the ones
I looked at were made in Brazil. The rear brakes were more of a challenge because I
found most of them didn’t have a provision for the cable type hand brake. Some kits
offered a type of hydraulic lockout valve equivalent to leaving the brake pedal
depressed but I believe there were geared toward off road buggies. In the end I
decided to purchase front and rear brake kits from a company called “Airkewld”.
They sell several types of brakes and the ones I chose use aluminum hubs with bolt-
on adapters with let you use any type of bolt pattern you want. I went with a 5 x 4.75″
bolt pattern which seemed to be a very common size with many wheel manufacturers.
Had I gone with the standard VW 4 bolt pattern I would have purchased them from
cip1
April 22, 2011 at 1:02 am #244372Front brake setup….
..and the rear which use standard VW beetle cables for the hand brake..
April 22, 2011 at 8:14 am #244373Thanks Calafer.
Really good info here!
PMOSSBERG40655.3436342593
April 22, 2011 at 9:40 am #244374Calafer
Did adding the adapters push the wheel rim further outboard? If so, can that be compensated for with the rim setback?
"If one thing matters, everything matters" - from the book The ShackApril 23, 2011 at 1:55 am #244375No, this specific type of disk brake kit doesn’t push the wheels further out. If
you use the adapters that bolt to the standard 4 or 5 bolt wheel hubs these
do increase the overall width from left bolt face to right bolt face by about 1-
1/2″ – 2″ total.
April 25, 2011 at 6:41 am #244376Thanks. That’s great information that I know many of us can use.
