Home › Forums › MGTD Kit Cars › VW Based Kits › Distributor Problem
- This topic has 6 replies, 4 voices, and was last updated 9 years, 7 months ago by
newkitman.
August 13, 2016 at 4:38 pm #301453
Hey folks.
Installed the electronic ignition module in Moneypenny, Put the electronic unit in, added the spacer ring for a stock distributor, put the magnetic rotor on, installed the ignition rotor…….the rotor doesn’t go on all the way. Took off the spacer ring and retried it. Same results. Its an ACCU-FIRE Ignition Module from EMPI. Oh yeah. The black piece with the little magnets in it does not index. It spins around. Could it be this is the defective component? Not sure what my next step is other than go back to points. Any suggestions? I’m stumped.
"If one thing matters, everything matters" - from the book The ShackAugust 13, 2016 at 9:17 pm #301456Maybe post a couple pics? I installed a Pertronix a couple years ago and it doesn’t sound like the same kit.
August 13, 2016 at 10:49 pm #301457Maybe check the O ring around the shaft on the new distributor. I had the same problem with mine and I put the old O ring on the new unit and it dropped right into place. Hope this helps.
August 14, 2016 at 2:21 pm #301481Ed. My coil is a Petronix and the ignition module is an EMPI Accu-Fire. I’ll pull the dizzy and get a better look at it and post pictures of what it looks like tomorrow. I don’t work on Sundays. Call me old fashioned but Sundays are my day of rest.
"If one thing matters, everything matters" - from the book The ShackAugust 14, 2016 at 5:51 pm #301483Hey Allen
taje a real close look at that black plastic part… It should have a square cutout with slightly rounded corners that match the dizzy shaft.
that part has to slide down the shaft and just clear the sensor or the rotor won’t engage properly.
i had the same issue and once I put a bit of force on that black part with the magnets it slid in place and the rotor also slipped on and engaged fully
luck tomorrow when you try to align that part an apply just the right amount of pressure to get it to seatbfully
happy jack
August 14, 2016 at 7:04 pm #301485Happy jack. I’ll definitely check that also. I’m thinking the locating pin on the module being a tad too fat or the spacer under the magnetic rotor not fitting down over distributer shaft all the way. More to follow tomorrow.
"If one thing matters, everything matters" - from the book The ShackAugust 15, 2016 at 10:49 am #301491Distributor problem update. Took the distributor out and took all the accu-fire electronic ignition pieces out and swapped with the Petronix ignition module etc. Turned out to be the spacer required for the stock vacuum advance distributor in the accu-fire ignition system was too thick and did not allow magnetic rotor and all above it to fit down all the way. All fits well now and distributor is reinstalled. Wife just back from class reunion in Wisconsin so now I have to do some hubby duties like pick her up at airport etc. Thanks everyone for your suggestions and encouragement.
