Door Panel Upholstery
Home Forums General Discussion Door Panel Upholstery
Viewing 8 posts - 1 through 8 (of 8 total)
  • #298121
    newkitman
    @newkitman
    Need to install the door panel upholstery. I don’t think any manual actually calls for installing 3/16″ cardboard underneath the upholstery but I’m thinking of adding it. has anyone used something as a backer for the door upholstery? If so, what did you use.
    #298174
    I used the hardboard type stuff they make pegboard out of. No holes, solid, about an eighth inch or maybe 3/16 thick. I could not make my own door cards because the pockets required a pro.
    #298437
    billnparts
    @billnparts
    Same here. Masonite with a thin foam pad added.
    "Drive Happy"
    #298465
    newkitman
    @newkitman
    Bill, Ed. Did either of you cut the hardboard where the door pocket is? Thanks for your replies.
    • This reply was modified 9 years, 8 months ago by newkitman.
    #298506
    secretagentcat
    @secretagentcat
    I have some thin cracked material behind my panels. I was thinking of using door skin form Home Depot to support the material.
    #298575
    Yes, the boards are cut for the pockets. The exact construction is a mystery to me, since i paid a pro to do it. The vinyl is marine grade. I copied the Moss replacements for the original vehicles.
    #298576
    newkitman
    @newkitman
    Thanks for all the replies. I’ll cut the boards for the pockets.
    #299702
    billnparts
    @billnparts
    My boards are not cut.
    "Drive Happy"
