Duchess factory Front suspension
Home Forums MGTD Kit Cars Chevy/Ford Kits Duchess factory Front suspension
  • #232868
    Steve Crites
    @ringo
    Larry,
    Yep, the front end on the factory car I have is a Chevette.  They moved the bottom shock mount from the top A-arm to the bottom A-arm and made a bracket on the top A-arm around the pivot points.  Simple, but it works good and parts are available.
    #240558
    Larry Murphy
    @larry-murphy
     Ringo,Thanks for the quick response and the picture too.My BCW has the shock mounted to the rear side of the lower control arm with the top end connected to a bracket coming off the frame.CMC used a similar set up but the shock is on the front side of the suspension.Again may I say you have a great MG replica.
