duchess/chevy chevette- will only start in park
Home Forums General Discussion duchess/chevy chevette- will only start in park
  • #303945
    Roger O.
    @oldmanrocks
    I was given a classic roadster duchess/ work in progress project car.  Its on a 85 chevette chassis.  The car will only start in neutral not in park.  Any Ideas?
    Also have been trying to remove the gear shift knob to replace but it will not budge… Any ideas would be appreciated.
    Thanks.
    #303954
    billnparts
    @billnparts
    Well, an automatic is unique. Make sure the shifter is adjusted correctly and the circuit is complete while in the park position. If that’s the case than the neutral safety switch would be suspect.
    "Drive Happy"
    #303956
    ray10
    @ray10
    The gear shift knob is held on by some splines it takes a little force but it will come off . I removed mine and made a wooden handle for it, and the emergency brake ,turn signal .
    on the neutral safety switch i would check that first.
    TDREPLICA Map
    #303966
    ray10
    @ray10
     here is a picture of the shifter .maybe?
    TDREPLICA Map
    #303967
    ray10
    @ray10
    Ok here is a picture of the shaft without the knob.
    here is the handle i made for it.
    here is picture of it together.
    • This reply was modified 8 years, 7 months ago by ray10.
    TDREPLICA Map
    #303975
    scubasteve
    @scubasteve
    Very nice woodworking. I think,”As much wood as possible.” I made a wood shift lever knob similar to yours, but just haven’t gotten around to putting it on. I guess I think it turned out so well, I’m afraid it’ll break!
    WOOD IS GOOD!
    Amor Conquista Todo
