Home › Forums › MGTD Kit Cars › VW Based Kits › Fiberfab – steering box replacement. How?
- This topic has 5 replies, 3 voices, and was last updated 8 years, 6 months ago by
September 15, 2017 at 5:43 pm #304076
Getting ready to tear into a Fiberfab for a customer. Steering box had been “adjusted” over the years by the owners kids and its a mess. Going to just replace it. What all needs to come off to get to it? The way it looks is that there is not enough room for it to lift up to clear the body. If there is a lot of hassle, it may be easier for me to pull the beam and replace it and then reinstall the beam. Looking for suggestions…Will be tearing into this in the next day or two. I did search, but did not find my answer. Thanks in advance.
September 16, 2017 at 11:29 am #304083Turns out it was really easy. Unbolted the coupler, and dropped the pitman arm. Removed the clamp. Gave it a slight twist and pulled it out the side. About 15 minutes into this and am installing the new box right now. Ponder this before cutting the body to make adjustments……Technically the steering box can be set up on a bench…
September 16, 2017 at 3:26 pm #304093Yep, I was about to say.
Remember when you put the new one in to line it up right-careful with the steering shaft, and to bend over those metal tabs on the clamp nut.
September 16, 2017 at 4:33 pm #304095I have a classic VW Resto shop, so I know what you mean about the tabs. Only issue I ran into was the adjustement screw was a bit taller than the stock box and was not clearing the body work. Cut about 3/8″ off and cut a new slot on the top. Set the toe and drove the hell out of it. Steering is still a little sensitive and tight, but I had rebuilt the front end on this car 2 years ago (new ball joints, tie rods, etc.) and he has put maybe 20 miles on the car since. And of course he forgot to put any fuel stabilizer in it when it sat for 2 years so his kid dicked with the carb adjustments to get it to run a couple months ago. Idle mix screwed the whole way in and idle set at 2000 RPMs……Gonna take the kids screwdrivers away…LOL…. Anyway – thanks and its going home in the next day or two and maybe he will start to drive it…..
September 16, 2017 at 6:37 pm #304096Ah, well-done, Andy. 20 miles in two years? This person is in for some shaming. 🙂 Hopefully he’ll redeem himself now!
September 21, 2017 at 6:07 pm #304126Well done Andy!
Hope you’ll stick around. Lots of VW powered TDr’s here. We could certainly use an expert advice!
Also hope you direct the Fiberfab owner our way!
