Just bought a never assembled Chevette MG kit. Plan is to use a left over 350 chev and a 200r4 trans. Not crazy about the chevette suspention the pinto more normall hot rod. Question is are the frames the same? If i remove coil spring pockets is rear same kick up? If I remove front mounts are frame horns same? Or is Chevette suspention OK? I think Front spindel same as Fearo so biger brakes may still be around? Tourqe tube rear is all the rage in Tour cars.
Maybe frame side detail or a aready build site recomdation?
