On a VW Chassis (pan) there is USUALLY a stud on the left rear frame fork that attaches the transaxle ground to the chassis ground. I have a 71 standard beetle chassis and there is a ground stud in the rear frame head just above the hole for the starter wire from the battery. I have welded a bolt to the front frame head plate for the front end grounds, welded a bolt to the top center of the tunnel right next to the front firewall and one on the rear for the engine compartment and rear grounds. All that having been said, do I need to have a ground wire from the transaxle to the frame?
On another note, I went to Wally World to get a battery. Used there battery finder book and computer and they don’t even list a VW Beetle. Last listing is a 74 Rabbi (oops! Rabbit). Guess I’ll have to run up to O’Reillys. Its been a busy day! Wow~! Its already beer thirty.
newkitman2015-04-26 17:31:39
