HOTT FuSE Home › Forums › MGTD Kit Cars › VW Based Kits › HOTT FuSE This topic has 5 replies, 4 voices, and was last updated 15 years, 7 months ago by Steve Crites. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts September 6, 2010 at 9:46 pm #233112 GaryParticipant @gary Still working on the MG but ran into a little problem with the headlight fuse getting really hot any one have any Ideas? Thx Gary September 6, 2010 at 10:05 pm #242154 edward ericsonParticipant @edsnova Do you have a relay switch installed? If so, maybe just change the fuse. I bew a couple yesterday for no apparent reason. Lots on my car are just old. September 6, 2010 at 11:17 pm #242155 Dan RosaParticipant @dan-r Gary If the fuse and wire getting hot if the fuse did not blow check that you have the correct gage wire to light ,it will over heat if it is to light to handle the amperage Dan September 7, 2010 at 8:33 am #242156 GaryParticipant @gary The Wiring is The orginal from Fiber Fab Harness not sure if maybe a short or if just not high enough gauge wire September 7, 2010 at 5:36 pm #242157 edward ericsonParticipant @edsnova Yow, I’m stupid. Don’t just put in a bigger fuse–not what I meant. Put in a good fuse of the correct size for that circuit, and see if it gets hot. Ditto Dan re the wire gauge. Feel and see if its hot. But definitely install a headlight relay switch if there isn’t one on the circuit already. Relays make everything better. Your headlights might be drawing more amps than the originals did. September 7, 2010 at 6:51 pm #242158 Steve CritesParticipant @ringo Ran into the same problem, (almost burned my thigh on the switch!). Relays fixed it! Looking at wiring diagrams, it seems they used the bare minimum on some of the circuits. Plan on relays sooner or later. Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
