Home › Forums › General Discussion › License plate bracket
- This topic has 11 replies, 4 voices, and was last updated 15 years, 6 months ago by
Steve Crites.
July 13, 2010 at 8:09 am #233047
My Ford based Fiberfab rear license plate is mounted on the bumper. Does anyone know of a quality bracket to move is up on the left fender area.
Help me spend my money.
July 13, 2010 at 8:24 am #241741Moss Motors:
Number 30 on this page is the bracket ($10.75)
http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexI D=32848#top
Number 45 on this page is the license plate lamp ($27.95 for reproduction or $85.95 for the Lucas part)
http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexI D=32988
July 13, 2010 at 8:30 am #241742On an original TD, the bracket mounts to an extension that I believe attaches to the rear tire carrier.
On most replicas I’ve seen, the bracket mounts to a flat steel/aluminum, bent at a ninety degree angle and bolted to the side of the rear engine cover/tank cover.
PMOSSBERG40372.3883680556
July 13, 2010 at 8:56 am #241743Look in stickney’s photo gallery to see an example of the 2’nd type Paul described . Looks really good . I think it is made of aluminum that has been polished or perhaps stainless. Great attention to detail.
July 13, 2010 at 9:13 am #241744I edited the response after you posted that Larry.
I think most of ’em bolt to the side of the rear cover, some are perpendicular, some match the slope of the engine cover.
Funny, I’m not even sure how my Duchess’ bracket is attached. I’ve got to look at it tonight.
PMOSSBERG40372.3888078704
July 13, 2010 at 9:21 am #241745Thanks guys looks like I’ve got some fabbing to do. Should be a nice project to work on. I’ll make a paper template and cut something out of metal.
July 13, 2010 at 9:26 am #241746Paul, I had not noticed that the license tag on the originals was vertical and have been trying to keep the one on my BCW positioned at the same angle as the ”gas tank”. I’m headed to the garage to make adjustments. The old saying ”It’s want you learn after you know it all” applies here. Thanks for pointing it out.
July 13, 2010 at 12:30 pm #241747Yeah. And in 1983 when I built my Duchess I definitely didn’t know it all! Thought I did tho!
I should have checked out some real TDs. Had I done that I would not have mounted my license plate the way I did.
July 13, 2010 at 12:48 pm #241748Dug around a little more. Buy the bracket from Moss.
And here is the light for less than $12.
http://www.englishparts.com/products/COVER–CHROME–LICENSE- PLATE-LAMP-OE–TR3-FROM-TS18913-TR3B–SPM–MGA-AH/2229/158-1 00.html
This is an alternative, bracket and light:
http://www.sullivansgarage.com/index.php?main_page=product_i nfo&products_id=806
July 13, 2010 at 1:01 pm #241749This is the last one. Here is the plate bracket and light from EMPI for only $13.00
http://www.mofoco.com/item/EMPI_9457_LICENSE_PLATE_BRACKET_L IGHT/515
July 13, 2010 at 2:25 pm #241750I’ve got the light and small bracket from the bumper mount and hopefully with some brackets I found down the celler I’ll be able to come up with the mounting bracket. Car is in NH so this weekend I’ll come up with the plan of attack. Think I’ll put an aluminum plate behind the plate to clean things up a little.
I’ll take a picture for you guys when complete.
July 13, 2010 at 6:52 pm #241751My bracket’s not proper, but the trim on the side of the “tank” is already cut for it, so…..
Thanks for the reminder about the plate behind the license, that would help dress up the whole thing!
