Home › Forums › MGTD Kit Cars › VW Based Kits › London Roadster – Donor VW Year
- This topic has 7 replies, 5 voices, and was last updated 11 years, 8 months ago by
greg press.
July 23, 2014 at 3:27 pm #235257
My London Roadster came with it’s own VIN number, concocted by the London Motors Corp. in Inkster MI. This has been quite a boon for registration over the years. The one place it fails me is in identifying the donor VW model year used in construction and thus in ensuring I’m getting proper parts and pieces.
The chassis number seems to have been ground off, obscured, or I’m just plain inept at finding it. Supposedly it’s on the tunnel, under the seat, just in front of the access panel. There’s no hint of anything ever being “stamped” there. I’ve checked many times as recent as last evening.
By process of elimination, I think what I’m looking at is a 1969 to 1971 donor. Here’s my logic, referencing http://www.vw-resource.com/years.html
– Cannot use the engine to ID as it’s likely not original to the frame
– Dual joint rear axles (IRS) introduced on late ’69 models in US
– Steering lock in ignition lock introduced in ’69
– 4xDrum brakes
– 4 Lug wheels introduced in ’68
– Old clutch throwout (not definitive) introduced new one in ’71
– Computer analysis wiring introduced in ’71 (not definitive, does not have)
– New steering column introduced in ’72 (need to check this one further)Your thoughts? Are there other indicators I can use to narrow the guess?
Those of you with London Roadsters and VW frames; is your VW frame number ground off or still there?
Stephen
Buxton, Maine
1982 London Roadster - "Kit Kat"July 23, 2014 at 4:08 pm #260774if you’re convinced there’s been an engine swap, you might try sanding cleaning the area in front of the access panel you referenced. that is where you’d find it if it hasn’t been ground out. Mine is not a London but it wasn’t visible till I wiped it down.
July 23, 2014 at 4:53 pm #260775The VIN is stamped into the chassis here:
July 23, 2014 at 4:54 pm #260776
July 23, 2014 at 9:26 pm #260777I was under the impression that my LR was a 1969 engine. When the rear wheel bearing was replaced I had to exchange it because it was the wrong one, The 1970 bearing was good. Who knows maybe a 1969 engine.1968 tranny, 1970 engine and the local hardware for other parts
July 23, 2014 at 9:42 pm #260778dunno-my flat 4 mechanic replaced my right rear wheel bearing with no problems..I wonder whats with the right wheel bearings going out ie 18k miles on the LR’s????
July 23, 2014 at 9:55 pm #260779Yes, have just been inept for 20 years. I looked in that spot time and again, but never took sandpaper to it. The paint had filled in the numbers, some sort of goey globby paint. I sanded it down a little and the numbers began to appear…
114 20xxxxx
August 1973.Happy to see my guessing was on the right track and not too far off. But happier to know what she really is!
Thank you all for your help, and encouragement to take out the sandpaper!
Buxton, Maine
1982 London Roadster - "Kit Kat"July 24, 2014 at 11:14 am #260780Mine went out at 18,000 right rear wheel bearing. Anyone else? Maybe there will be a recall
