MG TD Replica Manufacturers
Home Forums General Discussion MG TD Replica Manufacturers
  • #234920
    Brian
    @bcotton
    I am wondering if anyone knows of a TD replica manufacturer (still in business) that makes a complete, original looking, windshield assembly (frame , posts and mounting brackets) ?
    #257821
    newkitman
    @newkitman
    Here’s a link to an original TD windscreen frame.
    http://www.ebay.com/itm/Extra-Nice-MG-TC-and-Early-MG-TD-Rechromed-Original-Windshield-Frame-/370897006797?pt=Vintage_Car_Truck_Parts_Accessories&hash=item565b2f30cd&vxp=mtr
    #257822
    Brian
    @bcotton
    Thank you….I will check this out . I am hoping to make my Fiber Fab TD look more like an original MG.
    #257823
    We’ve been through this before in another thread. If I can find it, I’ll post the full link.
    Meanwhile….
    It is VERY likely an original frame will NOT fit.
    Width may be an issue.
    And even if it is not, most TD cowls are molded with flat extensions at either side where the frame sits. To fit an original frame, you will have to grind those off and patch & paint the fiberglass.
    PMOSSBERG2013-09-22 21:05:15
    #257824
    Brian
    @bcotton
    You are absolutely right….fitting an original windshield frame may/would require some body modifications, but I am prepared to do that. Thanks for your in-put.
