Only Tools You'll EVER Need
Home Forums General Discussion Only Tools You'll EVER Need
  • #304134
    scubasteve
    @scubasteve
    Clean out your tool boxes guys, here are the ONLY tools you will EVER need.
    Duct Tape and WD-40
    If it MOVES and it’s NOT supposed to, use Duct Tape.
    If it DOESN’T move and it’s SUPPOSED to, use WD-40.
    Simple as that….
    Amor Conquista Todo
    #304560
    BEBOP
    @bebop
    Eso es Claro.  Porque tu dice estas stupidas palabras,  no pregunta, un utensilio que tu no tienes, es un cerebro en la cabeza.   🙂
    #304561
    scubasteve
    @scubasteve
    Perdona mi intento de humor No lo intentaré de nuevo. 😳
    • This reply was modified 8 years, 2 months ago by scubasteve. Reason: errors
    Amor Conquista Todo
    #304563
    secretagentcat
    @secretagentcat
    And a Hammer for when all else fails!
