speedometer works, odometer don't
Home Forums General Discussion speedometer works, odometer don't
  • #235425
    Harry Lewis
    @spike-lewis
    Hi, My Speedometer works and is shows a bit faster than I’m really going but the odometer and trip meter do not work at all. I have the black face BDO unit, top speed 85mph. Do you think the unit is junk and where can I get a replacement.
    Thanks,
    Spike
    #261739
    Royal
    @royal
    Fixing these things is a bit like clock repair. IF you are ready to scrap the old one and buy new, first carefully take it apart. The problem is most likely a gear with a tooth worn down so much that it no longer engages the other gear it is supposed to mesh with.    Sometimes you can repair by building up the worn tooth (I’ve used epoxy or JB Weld) and by using jewelers files, make a new tooth. I’ve done it many times this way. What caused the problem is dirt or lack of lubrication on the odometer assembly. If you have some mechanical skills, good eyes and light, and steady hands, I’d bet you could fix it yourself.
    #261740
    Harry Lewis
    @spike-lewis
    Thanks for the reply. If I can find another I would give it a try and see if I could fix it. Trick will be finding another
    Thanks,
    Spike
    #261741
    Royal
    @royal
    VDO still makes instruments and tons of places carry VDO. Shouldn’t be hard to get an exact replacement (with just a little luck). I’m sure they have a website.
    #261742
    billnparts
    @billnparts
    VDO has an App.
    "Drive Happy"
