Variable Resistor
Home Forums General Discussion Variable Resistor
  • #309251
    Stefan
    @mgaggie
    My gas gauge and sender do not match resistance. I have done research into a product to mediate this issue and found variable resistors are my cheapest option… I think. I am not sure how to hook this up or which to buy, as there are multiple options on the market.
    Anyone used these or have a product suggestion?
    Thanks,
    -S
    #309256
    billnparts
    @billnparts
    Have you looked into purchasing a matched gauge and sender? There’s a bunch of various offerings on the market.
    "Drive Happy"
    #309299
    Stefan
    @mgaggie
    To answer the question here if anyone comes across this in the future:
    The variable resistor lets you know the range of resistance between the two.
    WHAT TO BUY: if this a problem for anyone, there is a device called the “Dolphin” and another called “MeterMatch,” both of which can be bought on eBay for 30 and 60 dollars respectively. They both operate as a mediator between the gauge and sender for your fuel system. Essentially, the device will regulate the resistance between the two automatically.
    I bought the Dolphin. It took 15 minutes to set up, and it came with decent instructions. Completely solved my issue, and now my gauge properly reads the level of fuel I have. So far, 10/10 purchase
    • This reply was modified 12 months ago by Stefan.
    #309306
    billnparts
    @billnparts
    I’m glad you found the solution. I wasn’t aware there even was such a device.
    "Drive Happy"
