Velocity Ring for Fan Shroud
Home Forums MGTD Kit Cars VW Based Kits Velocity Ring for Fan Shroud
  • #234888
    HappyJack
    @happyjack
    Has anyone installed a velocity ring (vortex ring;  Venturi ring) on your fan shroud?  The sellers of these things claim significant temp. reduction due to the vortex effect of the air flow over the bell-shaped exhaust opening in the shroud with this ring installed.
    Here’s a picture and write up (a.k.a. marketing) from the Awesome Powder Coat site.  Sounds a lot like MAGIC, huh?  Any experience with this method of reducing engine temperature?
    Thanks,  Jack
    To get the maximum possible cooling out of your VW
    you need a velocity ring (also called a volute ring, or
    just a cooling ring). This is an American made model
    fuel injected fan shrouds.  Cooling is improved by increasing the air velocity
    through the fan. The rings are all stainless steel
    construction, with spot welded mounting tabs and a
    satin black power coated finish. They can be installed
    on any factory or aftermarket doghouse fan shroud by
    welding or rivets.
    A version for the early fan shroud is also available.
    * Made in Ohio, USA
    * All Stainless Steel Construction
    * Works on all Doghouse Style VW Engine Tin
    *Improves engine cooling
    #257592
    I’m skeptical…
    #257593
    Ed Service
    @eddy
    VW installed it on all 1975 and newer fuel injected bugs so it’s gotta be good! right?
