Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › wheels
- This topic has 8 replies, 5 voices, and was last updated 10 years, 4 months ago by
scubasteve.
November 8, 2015 at 9:23 am #235918
Looking at tire choices for the 14 x 6 wheels and it is fairly limited and getting worse over time as manufacturers stop producing 14″ tires. Looking for 15″ rims to fit also looks fairly limited, only a few choices with the 4 x 108 pattern and 0 offset.
Looking for any suggestions you might have?Bill, are the fox body police wheels a + offset (larger back set) and are you running spacers with them?Thanks, T. J.November 8, 2015 at 11:38 am #266176Try Coker Tire Company. Not cheap, but they have a lot of 15″ tires in VW sizes, including the narrow period-correct wide white walls that I have on my car.
November 8, 2015 at 7:40 pm #266177The 15″ mustang police wheels actually have less offset than the 14″ Cragar wires. The 195/70R14 on the wires will rub the fenders without raising the ride height with the coil overs. The 15’s sit in a bit further allowing the car to be lowered. Running 205/60R15’s. We had 235/60R15’s on the rear before we dedicated those wheels for the race tires. We’re only talking about 1/2″ in height. I also have a set of 14″ steel wheels from a Ford Fairmont. These also sit inboard with no rub issues. These actually have snow tires on them.billnparts2015-11-08 19:41:26
"Drive Happy"November 9, 2015 at 8:01 pm #266178Bill,Any thoughts on where to find police wheels?
BTW I meant negative offset, clumsy fingers.November 10, 2015 at 6:36 am #266179I was fortunate to be working at a Ford dealer when they were procured. They might still be available through the dealer parts chain, albiet rather expensive.
"Drive Happy"November 10, 2015 at 8:19 pm #266180They get mentioned on enthusiasts sites occasionally. Apparently fairly rare and spendy.
Why not re-drill your hubs at 4 x 4.5 and get a wide selection of possible wheels–including (but not listed at that link) original MGA steelies that look just like TD wheels (12-holes instead of 15) and take the same hubcaps? Or–and this can happen, just ask Roy–the adaptor hubs from Triumph TR3 wire wheels?4 lugs spaced at 4.5 inches.edsnova2015-11-10 20:23:40
November 11, 2015 at 10:48 pm #266181What do you all think of the mustang II “phone dial” 10 hole alloy wheels? They must be lighter than the steel wheels.
November 12, 2015 at 7:00 am #266182That same 4bolt pattern runs into the early 90’s until they went to a 5 bolt. Availability in 14″, 15″ and 16″.There’s a lot of options out there. Have you checked Tire Rack or other wheel outlets?
You can get 5 bolt rotors that fit the spindles and as you dont have a rear axle yet, you could get a 5 bolt axle easier than a 4.Bill Ascheman
"Drive Happy"November 13, 2015 at 10:23 am #266183I don’t know if these will help, but check out:
http://www.mamotorworks.com/VW/product/15-x-45-wheel-stock-steel-silver-4x130mm-obi108017-2-4
They’re on sale. But there may be others at this site.
Lots of other bits there, too.Amor Conquista Todo
