Home › Forums › Classifieds › MGTD Kit Parts and other stuff › TYPE L 549 tails lights
- This topic has 19 replies, 7 voices, and was last updated 13 years, 3 months ago by
October 12, 2011 at 12:34 pm #233753
A pair of very old new parts – still in original boxes.
A good price wanted
Can send photo as not used to this site yet.
beenthere
07711 752887
October 12, 2011 at 2:28 pm #246932are these the ones you have and how much
TDREPLICA Map
October 12, 2011 at 3:44 pm #246933I saw the ebay ad that Ray10 linked to for those pictures.
I beleive the lenses are correct. But those are not TD bases. They are probably for an MGA. The ebay ad is wrong.
This is an L549:
Beenthere…are you able to clarify based on the pictures?
PMOSSBERG40828.6618287037
October 12, 2011 at 3:48 pm #246934And for what it’s worth…complete L549 reproductions, including lenses, bases, bulbs and gaskets are available for $70 a pair.
http://jollyrogersmotors.com/node/214
PMOSSBERG40828.6782638889
October 12, 2011 at 3:55 pm #246935If the L549 was used on MG TDs, this explains how the same L549 can be used on an MG TD and an MGA with very different slopes to the rear fenders.
On an MGA the L549 mounts to an additional base, normally painted body color:
Now read the next post about the correct TD tail lights.
PMOSSBERG40828.6790046296
October 12, 2011 at 4:09 pm #246936The L549 would work and look MUCH better than VW tail lights. But the L549 is not the original TD tail light.
There are two styles of lights used on original TDs.
Early TD’s have a more rectangular/squared off lens.
Later TDs and TFs used a simple round tail light
This is a line drawing from Moss Motors, but I think you can see the difference to the L549 lens and base. The early TD is in the box labeled “54”, the later TD and TF is in the box labeled “61”:
Here is a rear shot of an earlier TD. You can see the “squared” tail light:
And here is a 1953 round tail light TD:
Sorry to be so anal about this. But a lot of what we do here is educate each other. If you are trying to achieve an authentic look and are going to spend money doing it, I just want you to make informed decisions.
PMOSSBERG40828.6854050926
October 12, 2011 at 4:32 pm #246937Paul thank you for clearing that up , I didn’t think about the other style of tail light. And you can be as anal as you want. that is how we learn.
TDREPLICA Map
October 12, 2011 at 5:11 pm #246938Bravo, Paul.
I do believe that MGA style light looks a little better on most replicas than the original deal, because the replicas usually have the VW plinth molded in to the fender. The MGA item is, I think, a little bigger and seems to blend better than the early TD style. The round ones–forget it, unless you’re grinding and re-filling the molded plinth part on your fenders.
All bets off for those with BCWs (early style TD tail lights, standard equipment) or Allisons (which come with the late round tail lights).
October 12, 2011 at 11:23 pm #246939Ed, that is a great observation!
That molded in part on my Duchess’ fenders is what has kept me from installing the set of reproduction original TD taillights that I have.
I may take a look at the MGA lights.
October 18, 2011 at 11:44 am #246940A little late but,, Morris Minor, MGA ,Triumph and others used a lucus # L549 plastic light lens that will screw to the ‘LUCKY’ light base that seem to be used on most kits other than VW they were an exact fit on my car
And you can find them made of Glass ! Dan
October 18, 2011 at 5:39 pm #246941Dan…what is the “LUCKY” light base?
October 18, 2011 at 6:36 pm #246942Paul, Look in the photo gallery at RedMGTD,RichBelfay,RobBaker’s cars .They all have the ”Lucky” taillights.I think they are usually found on CMC front engine cars but I have seen them on VWbased cars as well.
October 18, 2011 at 9:52 pm #246943Larry That’s it.. Dan
October 18, 2011 at 10:01 pm #246944Got it. thanks. I had never heard them referred to as “Lucky” talilights
October 19, 2011 at 8:34 am #246945Who knew I had lucky taillights I thought I was lucky just because they work most of the time 🙂 RobBaker40835.364849537
October 19, 2011 at 11:44 am #246946More Lucas optimism, for sure!
October 19, 2011 at 8:46 pm #246947Lucky if they work most of the time !!I have repleced all 4 sockets,
Dan
October 22, 2011 at 9:59 pm #246948Ok here are the tail lights that beenthere has for sale . make offer?
TDREPLICA Map
November 8, 2011 at 11:26 am #246949Gents,
Sorry for my absence.
Ray 10 has kindly posted the photo.
As you can see these are original parts.
I still have them and can deliver them anywhere between Preston and Essex.
Any offers?
Cheers
beenthere
November 8, 2011 at 12:43 pm #246950Hi DAvid (beenthere).
What are you asking?
And what would the expense be to ship to the USA?
Thanks!
