I finally got around to the modification of the High Mount Stop Lamp.
I had been running a lamp from a GEO Tracker that stood above the spare tire.
When I removed the rear cover to repair a crack I removed it and glassed over the
mounting holes.
I had never been able to find the correct center cap for the wire wheel cover
mounted on my spare, so I drilled out the center hole to accommodate a rubber
grommet and LED lamp originally used as a marker lamp on big trucks and trailers.
Yes, It light up red.
Bill Ascheman
Fiberfab Ford
Modified 5.0, 5sp., 4:11
Autocross & Hillclimb
"Drive Happy"
