Home › Forums › MGTD Kit Cars › VW Based Kits › Another Shifter Question?
- This topic has 3 replies, 4 voices, and was last updated 14 years, 5 months ago by
Tom Colello.
October 23, 2011 at 1:27 pm #233775
I would first like to say this is my first experience in
driving a VW. My TD is built on a ’68 VW chassis and I
thought the shifting had a lot of play in the stick. I
did have the pedals moved closer to the seat, but still
have a bit of a reach for 1st & 3rd gear. I bought a new
“stock shifter kit” hoping to take the loose play out,
and to have a spare after I tried heating and bending the
original, to bring the shift knob into easier reach. The
stick had a T-handle which I thought the threads were
stripped, because when turned it would never tighten to a
fixed position. After removing the shifter I noticed the
ball bearing in the side of the ?ball? at the bottom of
the shifter. I have not been able to locate any
information if this ball bearing needs to be any
particular position when reinstalled. After bending the
old shifter and re-installing I realized that the T-
handle is not stripped, it is tight ? the continuous
spinning is the entire shifter. Is there any way to
prevent this spinning? Because after bending the shifter
it takes a lot of concentration to not spin the shifter
around, putting 1st & 3rd gear even farther out of reach.
Maybe bending the shifter was not such a good idea? I do
see a lot of parts suppliers sell T-handle and Trigger
shifters that are bent. Do these spin around also? If
not, how is the spinning stopped?
Hoping someone can give me some direction on how to
proceed ?
Thanks for the help, this is a great site for
information.
Donna
?Go Saints!?
October 23, 2011 at 7:58 pm #247303When you removed your shift lever did you get a good look at the shift rod socket? Some of the older stock VW shift levers had a rivet and pin on the shift lever ball. That pin fit into the slot in the shift rod socket. Over time the pin would break allowing the shifter to spin in the socket or the the rivet heat would wear out. VW put the shift pattern decal on the ash tray because the shift lever spun. The newer shift levers just have a slightly larger ball on the end and it too gets worn out over time. Perhaps a beead of weld on the rear side of the shift lever ball. If non stock, can’t really say. I have a T-handle sahifter in my Ghia and don’t have a swivel problem.
"If one thing matters, everything matters" - from the book The ShackOctober 23, 2011 at 9:33 pm #247304The 1967 and earlier Type 1 (Beetles) have a slightly curved shift lever. There is a pin on the ball that keeps it from rotating.
1968 and subsequent model years have a straight shift lever. VW dropped the pin because it was no longer “necessary”.
More discussion here on the Samba:
http://www.thesamba.com/vw/forum/viewtopic.php?t=221549
October 24, 2011 at 10:41 am #247305Hey Donna, Glad to see another TD owner from Louisiana. I live in Baton Rouge. If you ever go to the Golden Oldies Car Show in Hammond I’m usually there with my other VW friends. Would love to get together. There’s only one more show in Hammond and it’s the 2nd saturday Nov 12th. It’s at the mall back by Academy Sports. If the weather’s good we’ll be there with Winston. Hope to see you there. You can get in touch with me via PM here or email me at fourbplasticsinc@bellsouth.net.
