Home › Forums › General Discussion › Battery Tenders
- This topic has 3 replies, 2 voices, and was last updated 15 years, 11 months ago by
Dan Rosa.
October 23, 2009 at 7:49 pm #232776
A while ago, there wasa thread about battery chargers.
Eastwood is having a 72 hour sale on Battery Tender products
http://www.eastwood.com/email/default3.asp?SRCCODE=1EMA09S&a mp;a mp;SKW=EM557&utm_content=25%25+Off+Select+Battery+Tender s!&utm_campaign=10-23-09+25%25+Off+Select+Battery+Tender s!&utm_source=iPost&utm_medium=email
Battery Tender are used by most of the forum members that replied to the prior thread.
I have two Battery Tender Jr. 12V, one on my Duchess, the other on my 65 Plymouth.
PMOSSBERG 40109.8343981481 Paul Mossberg
October 25, 2009 at 3:39 pm #239932Paul ; They work ,I also use one, but nothing replaces starting once a week and just listening to the sounds the engine makes, and hope nothing out of the ordinary! on my boat at the dock I have used one that works in sunlight, but in the garage there is not enough sun light to make it work. I hate to put it up[ the TD ] for the winter, A day here and there 75 degrees to day great driving in the fall. Dan
October 26, 2009 at 1:26 am #239933I agree the best driving weather is a clear crisp fall day! Drop teh top, bundle up, put the heat on if you have it, and go!
Re starting up while the car is otherwise idle, I am not an engineer. But I have been told one of the worst things you can to an internal combustion engine is start it, let it run for a few minutes and shut it down.
The engine needs to come fully up to normal operating temperature and be run for a while before shutting down again.
If you cannot do that, it is better to just leave it alone.PMOSSBERG40112.3782175926
October 26, 2009 at 8:25 pm #239934Paul ,you were told correct let her warm up, put on a good CD and relax
but keep the garage door open!! windows to ,on mine 2 sides open[doors] being a warmer climate than N.J. I did that so inside would not get to hot in the summer!!and out of the rain
my wife would not lit me put A/C in the work shop or the garage so I did doors
A good driving day 71 and sunny leaves are turning and look great. Dan
