Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › BCW help, please
- This topic has 12 replies, 5 voices, and was last updated 14 years, 5 months ago by
September 3, 2011 at 9:49 pm #233662
First, many thanks to all who responded to my introduction thread. I gained
a little knowledge and am looking for more. No manuals, books or
documents other than an original BCW brochure and the title came with her
so I’m really in the dark. I suspect the Chevette book that’s in the mail will
be helpful but I’m betting BCW also did some things that won’t be in
there…which brings me here:
I’m calling that the transmission mount. Looks rotten to me, the arrow
points to a tear in the suspension donut. Anyone know if it’s a stock
Chevette item or another mount subbed in?
September 3, 2011 at 10:50 pm #246252Yes that is a stock trans. mount you can order it through any parts house.
OR try to get in touch with a guy name Rick Drake at the chevy forum he is the god of chevette parts.
and you can order parts through him.http://members.boardhost.com/Vette_Man/
TDREPLICA Map
September 4, 2011 at 8:48 am #246253Thanks, ray10. Yep, got me a replacement right off the shelf at my favorite
parts store. He’s had 2 in stock since the 80s, the box looked antique.
Hopefully the rubber is still sound, seems fine on the surface.
I’ve been in touch with Rick because with that much play I suspect the carrier
bearing (he called it an axle extension) is probably beat, too. He’s pretty
quick with answers and parts quotes. Still, I’d rather pop that “new” mount in
first and just see where that leads me. I could get luckyoldroadie40790.3672800926
September 4, 2011 at 9:14 am #246254To my understanding there should be some play side to side and up and down ,but none front to back.
TDREPLICA Map
September 4, 2011 at 9:38 am #246255ray10 wrote:To my understanding there should be some play side to sideand up and down ,but none front to back.
Thank you, that gives me something to check once i get this baby up in the
air.
September 7, 2011 at 1:23 pm #246256Okay, so she’s up on jack stands in the rear, front wheels chocked and I’ve
got the nut and big washer off. You can plainly see the mount is torn when
the floor jack starts to lift the trans. I can’t seem to get the tans up high
enough to clear the trans bolt. Still no Chevette manual so I’m just going on
past limited experience…does this mean I don’t have enough tunnel
clearance to change the simple mount? Or, maybe this is a stud and I can
remove it by double nut method?
September 7, 2011 at 2:08 pm #246257Oldroadie…
I have no idea if this will help or hurt…but Pink MG had issues with the transmission mount in a Chevette powered BCW.
Mark believes BCW built running chassis, then bonded the bodies to the chassis, forever sealing in the engine and trans! There is no clearance above the transmission.
Your diificulties raising the trans high enough to remove the bolt make me suspect you are running into the same issue.
Here is Pink MG’s trans mount saga:
https://tdreplica.com/forum/forum_posts.asp?TID=139&K W=transmission+mount
September 7, 2011 at 3:06 pm #246258Paul, Thanks for the link to Mark’s BCW trans and other stuff . I thought I had read everything about what’s now my pride and joy but had missed that one. I had tried to explain the clearence issue to OldRoadie but this is much easier to follow since Mark actually did the disassembly and redesigning of the trans mounting plate. Larry Murphy40793.630150463
September 7, 2011 at 3:54 pm #246259Not bad for a VW TD owner, eh?
September 7, 2011 at 4:06 pm #246260Thanks fellows. I had misunderstood about the tunnel issue and thought
it just hampered removal of the entire trans. I see now it’s a bigger chunk
of work to just replace the tans mount. Not impossible, just more to do.
The link to PinkMGs pix is very valuable, I had not found that thread
before. I might just ponder cutting the mount away and re-engineering it
rather than pulling the entire engine and trans and cutting the fibreglass
floor.
Whatever happens next I’ll be certain to document it for the next BCW
rebuilder that comes along.
And, there’s another complication. My wife got herself t-boned in town
yesterday in the rain and her car might be totaled as the ‘B’ pillar was
bent all the way into the driver’s seat. It did it’s best impact absorption
crumple and it kept her from getting hurt but now we’re out a car. Looks
like the MG might take a back seat for some time…I’m hoping I don’t have
to sell it to get her back on the road.oldroadie40793.6745601852
September 7, 2011 at 5:46 pm #246261Thankfully, your wife is OK!
The other car stuff takes a back seat to that!
PMOSSBERG40793.9689699074
September 8, 2011 at 4:10 pm #246262Yep, she’s fine and that’s the main thing. It’ll be interesting to see what the
adjuster says about the car; I’ve never seen one with that much bent in the
‘B’ pillar ever track straight again.
Mrs. T even helped me install spring rubbers in the rear this morning after
we fetched the police report and voila! no more bottoming out. Shocks seem
to be doing fine duty and if the rubber insert keeps the bottoming out at bay
on the road it’s even better 🙂
September 8, 2011 at 4:57 pm #246263Nice!
