My brake master cylinder has been leaking slowly and since today was dry and warm enough to work on the problem I went at it. Checked all the brake lines from the reservoir to the MC and all were good. Then checked all the brake bleeder screws and they were good. Checked the brake lines into each brake cylinder and found the nut to the right rear brake cylinder was cracked. I’ve replaced the brake line and serviced the brake system and did another bleed. We’ll see how it goes after I install the new wiring harnesses from Rebel Wiring.
Will report as soon as I’m done. Until then, Happy Valentines everyone. Remember to show yer TDR a little love! ๐ ๐
