Home › Forums › MGTD Kit Cars › VW Based Kits › Building My TD Windshield
- This topic has 5 replies, 3 voices, and was last updated 12 years ago by
Mike Schumacher.
September 8, 2013 at 3:47 pm #234895
Well my neck is A-Okay and the doc (I call him Bones) says I’m cleared 100% for normal duty. After step son’s B’day dinner today I’m starting on building my TD windshield. I plan on taking pictures each step and posting so others here will not suffer the pitfalls I do; if I run into any. I figure I have three more weeks till a three week trip to DC for the next mod. I should get quite a bit done on the TD in the next three weeks.
newkitman 2013-09-08 15:48:54 Allen Caron
"If one thing matters, everything matters" - from the book The ShackSeptember 14, 2013 at 2:36 pm #257637Okay. While some fiberglass work is drying I start to assemble the windshield assembly. Not a big problem but it will definitely take two people. What I found to be the hardest is making the seal fit around the corners. Even cutting a dart at each corner its tough. Anyone have any suggestions. A series of pictures to follow when I get it all done. OH! The instructions in the assembly manual are somewhat different than the instruction sheet that was packed with the windshield glass.newkitman2013-09-14 14:38:13
"If one thing matters, everything matters" - from the book The ShackSeptember 14, 2013 at 6:26 pm #257638I placed seal into frame as well as I could and used ratcheting tie downs to encourage into frame. Trimmed what I am calling excess seal. Seems seated and square fits as it should on body but is not mounted, and months from road test.
I’ve done it before but for the life of me I can’t upload picture.
Oh evidently I canjuneybug2013-09-14 18:50:29September 14, 2013 at 6:42 pm #257639Believe it or not, if you use isopropyl(rubbing alcohol), getting the glass and seal into the frame is easy peasy. There are several trial fits. One to get the glass into the frame; one to get the bottom rail lined up and sealing properly on the bottom to the body and mark where the screw goes and at least one more to fit the whole shebang to the car body.
"If one thing matters, everything matters" - from the book The ShackSeptember 14, 2013 at 9:15 pm #257640Mike,
Did you fasten the bottom piece to the sides?
Not sure if all the kit assembly manuals showed this, but on my Duchess, there is a single screw on each side, through the side rail and into the channel that is on the bottom of the bottom piece of the frame.
Take a look at pages three and four of Part 4 – Body and Interior of the Classic Roadsters assembly manual:
https://tdreplica.com/Manuals/Duchess/Classic%20Roadsters%20VW%20Duchess%20Part%204%20-%20Body%20and%20Interior.pdfPaul Mossberg
September 14, 2013 at 10:36 pm #257641not yet but I will thanks
