Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Chevette Water Pump
- This topic has 6 replies, 3 voices, and was last updated 15 years, 8 months ago by
Larry Murphy.
July 23, 2010 at 6:22 am #233056
I have Chevette based FiberFab and am doing a head, ring, etc. job. While in
there I am replacing the water pump. For the life of me I can’t get to the
bottom pump mounting bolts. Following Chilton instructions doesn’t allow
access to the bottom bolts. Can anyone help?
Ballard Ed 40382.2665509259 July 23, 2010 at 8:51 am #241806Ed
I’ll check my Haynes manual when I get home.Ringo
July 23, 2010 at 10:37 am #241807Ed, The Factory Chevette manual as well as the Haynes manual say that the crankshaft pulley and also the timing belt must be removed.
Is the pulley what is keeping you from getting to the bolts. Both books indicate that the pump can be removed with the engine in the car after removing fan and the alternator , AC, and PS belts as well as the timing belt and it’s cover.It looks like the timing belt cover is in two pieces with one of them being behind the crankshaft pulley.
July 23, 2010 at 6:09 pm #241808Ed,
Checked the Haynes and it’s like Larry said, two piece cover with the bottom bolts of the water pump lookin’ like they’re behind the plate that surrounds the crank snout.
July 23, 2010 at 6:25 pm #241809Ringo, I ‘m glad you checked on this as the pictures and instructions were a little vague to my senior brain. It looks like the factory engineers designed it so it would not be user friendly.
August 1, 2010 at 4:43 pm #241810Thanks to all for replies. My GM Service Manual arrived over the weekend
and it has better illustrations, plus I have looked closer. Now I see that the
lower cover is more extensive than I thought. When removed it will give
access to bolt heads. Hope I didn’t inconvenience anyone.
Ed
August 2, 2010 at 10:18 am #241811Ed , It was no inconvience at all. Now if I have to replace my water pump, I know to allow extra time because of all the extra complications. As is the case quite often on this forum ,one member’s problem gives all of us an opportunity to learn the solution and know just what we may be facing down the road.
