Home › Forums › MGTD Kit Cars › VW Based Kits › Classic Roadster Gas Tank
- This topic has 10 replies, 7 voices, and was last updated 14 years, 1 month ago by
Rick.
February 23, 2012 at 8:56 am #234002
Hey fellow Duchess owners…..can you send me a photo or two of your gas tank?
I know this kits comes with a customer gas tank but when I got my car they had replaced it with a plastic marine tank.
My son will be building me a new one but I’m trying to get a clear understanding of the dimensions and how it sits the space allotted.
ALSO, for those willing, I’m wondering how far your steering wheel extends out from your dash. Mine seems to be pretty long but I have no reference point.
Thanks
February 23, 2012 at 9:09 am #249357Not a Duchess, but a MiGi. Mine is 5 1/4″ to the wheel spokes.
February 23, 2012 at 9:14 am #249358Rocky,
VW, right?I’m unable to get you photos at the moment. It’s a long story, but my Duchess is still ocked up at my former residence, now occupied by my futuer ex-wife.But you can see pictures in the Class Roadsters assembly manual, available in the Download Manuals section of this web site.Downlaod Part 2 – Body Assembly. The tank installation is on pages 44 and 45 of the manual, which are pages 23 and 24 of the PDF.The tank is about 12 inches deep and is shaped to fit the VW floor panels in front of the passenger. It fills almost the entire space. The left side is square to the front and back, and the right side of the tank follows the angle of the floor pan.The tank is held down by a single metal strap, from the outer floor pan, across the top of the tank to the center tunnel.The steering column installation is in Part 4 – Body and Interior. You can get some idea of the spacing from the picture. I think I have about four inches between my wheel and the dash. There isn’t much room for the builder to modify this, unless he/she fabricated their own parts. Classic Roadsters provided a column extension, which fits between the VW column and the steering box. If the builderof yoru car used that part, the column is sitting as CR designed it.Hope this helps.And I hope even MORE to be able to actually access my car within a month or so.PMOSSBERG2012-02-23 09:17:19
February 23, 2012 at 9:16 am #249359Rocky,
My car is pretty close to Royal’s. But I think my wheel sits a bit closer.Something else to point out….you need a flat steering wheel with zero dish! Just like the one on Roy’s picture.PMOSSBERG2012-02-23 09:16:21
February 23, 2012 at 2:49 pm #249360Rocky if you want a new steering wheel check out raptor Steering wheels ,
(info. provided by Mike N Scarlett )TDREPLICA Map
February 23, 2012 at 3:33 pm #249361Cool options Ray10 but I like my steering wheel (however those are pretty tempting). I’m thinking my steering column may need to be shortened. I’ll just have to wait and see once I get the seats in.
February 23, 2012 at 10:01 pm #249362Hi Rocky,Although my car is a Lafer it seems that my tank is similar to the one described by Paul. It is aprox. 11″ tall and the filler sits inside the front trunk. I made a strap for it but ended up running the single strap from front to back instead of side to side as described by Paul.I spray painted the tank and then added several layers of clear enamel. I also coated the bottom of the tank with a rubberized paint in case the bottom floorpan got damp at some point..
This second photo is of the tank installed inside the front trunk area…
Let me know if you want more info regarding the tank..RicardoFebruary 24, 2012 at 7:59 am #249363Four inches to the wheel spokes. Looks right, I think.
here’s a comparison shot:
Worth noting that TD’s had adjustable steering columns. The wheel could be set in or out about 2 inches. No tilt, unfortunately.
edsnova2012-02-24 08:02:03
February 24, 2012 at 9:07 am #249364Rocky,
Ricardo’s tank is very similar.If your Duchess was built per the factory specs, the filler tube enters the tank at the top, left, front corner. It runs under the weight box at the front of the trunk, then up behind the grill to the “radiator cap”.This is VERY entertaining at gas stations! Dropping the gas nozzle into the radiator creates some interesting reactions!Paul Mossberg
February 24, 2012 at 10:14 am #249365PMOSSBERG wrote:Rocky,This is VERY entertaining at gas stations! Dropping the gas nozzle into the radiator creates some interesting reactions!Agreed my fuel cell is mounted just behind the grill and the looks are great.
February 27, 2012 at 1:45 pm #249366Thanks for the great info and pics. Sorry for the slow response but I got distracted by my wiring research and forgot to come back to this string.
VERY HELPFUL!!!
