Home › Forums › MGTD Kit Cars › VW Based Kits › Clutch cable issue
- This topic has 8 replies, 5 voices, and was last updated 12 years, 7 months ago by
dggrant.
August 29, 2013 at 6:43 am #234874
Annie’s clutch cable snapped on the way to the repair shop, so I asked them to replace it. They tell me that the ordered the oem cable for a 1970 VW Beetle (which should be correct) but when it arrived it was about a foot too long.
Any idea why this should be the case or what I should do now?
August 29, 2013 at 7:00 am #257521They have the correct cable – which will be too long. Your TDr front seat is not in the same location as on a “bug”. It and the controls were moved back about a foot therefore the cable is a foot too long. They can easily take up the slack at the clutch arm on the side of the transaxle.
If they could not figure out how to do this, you might want to get another repair shop to do your work.August 29, 2013 at 8:08 am #257522You can loop the cable and double clamp it to make it the correct length or cut it and double clamp it to splice it back together. Small U Clamp’s.
Allow for some adjustment at the clutch arm. The clamps should be between the cable tube and the clutch arm.gbidick2013-08-29 08:16:15August 29, 2013 at 9:23 am #257523Thanks guys. I had been telling them that the frame had not been shorterned. Didn’t even think about the pedals being moved
I called and they had just worked it out themselves by looking at the snapped version which was looped and clamped (Duh).August 29, 2013 at 10:47 am #257524Good deal. That’s the way all of our (VW) clutch cables are rigged.
August 29, 2013 at 1:10 pm #257525Not mine – full length on Fiberfab – bars from standard location to the new set.
August 29, 2013 at 1:21 pm #257526Mine too.
August 29, 2013 at 2:52 pm #257527Of course you are correct. I forgot that some of the kits used pedal extenders.
August 29, 2013 at 3:53 pm #257528Wow, another reason that Annie is not a Fiberfab!
She seems to be one but with too many differences which are now:Shorter windshieldTD badges on Steering wheel and radiator5 gal gas tankNifty compartment under hoodPlain dashboard.Clutch cable needs to be shorterned.She doesn’t seem to fall into any of the other major manufacturers. So I either have a hybrid or a mutt
