Home › Forums › General Discussion › Convertible Top Rear Window
- This topic has 16 replies, 8 voices, and was last updated 12 years, 8 months ago by
newkitman.
June 30, 2013 at 7:58 pm #234786
Second question (as previouisly posted)
Does anyone have a rear window in their convertible top that zips open? I have seen pictures of TD replicas with them but can’t identify the kit. Are they something that is made local to them?ThanksAllen Caron
"If one thing matters, everything matters" - from the book The ShackJune 30, 2013 at 8:13 pm #256894Hey Allen,
All I know for certain is the Classic Roadsters LTD Duchess stock roof had a sewn in rear window.
June 30, 2013 at 9:30 pm #256895Paul,
My CMC/Fiberfab kit, like your Classic Roadster Duchess has the rear window sewn in. And according to the illustrations in the Fiberfab assembly manual, that rear window is also sewn in. Perhaps someone with a Migi will chime in.newkitman2013-06-30 21:31:39
"If one thing matters, everything matters" - from the book The ShackJune 30, 2013 at 10:20 pm #256896The VW based Daytona MiGi is sewn in also.
June 30, 2013 at 11:49 pm #256897I have a FF-II that I just purchased back in May — It has a tan cloth top with a zip open rear window. There are straps on each side of the window with snaps — so the window can be rolled up and snapped in the rolled position. But I’m not sure if this was a “stock” Fiberfab II top and side curtains. I’ll upload some pic’s tomorrow.
July 1, 2013 at 2:06 am #256898Anonymous
InactiveI have a early Fiberfab kit car. It had a rollup window as you describe. While taking it apart to make pattern for new top came on a label of a Pa upholstery shop label found under a top bow cushion pad. As the top was well worn suspect it was original to the kit. Supect it was supplied to Fiberfab by the shop in Pa. As I have found out Fiberfab kits were built in PA, Florida, Migh, and California.I did not make my new top as a un built CMC kit was bought and it had 2 tops with it . Both had sewn in windows. As the kit was a later kit suspect the sewn in window was a cost cutting factor for manfacture. Sewn in windows cheaper to make no zipers to install.I do like the rollup window better than the sewn in window.i have an early fiberfab kit that had a zipup window as you describe.July 1, 2013 at 3:42 am #256899A good upholstery shop should be able to modify the window in your top. I, personally never did it, but when I used her as a daily driver I had a shop install quarter windows in the top for visibility. They did a nice job and it looked good. The zippered window should not be difficult.
"Drive Happy"July 1, 2013 at 11:02 am #256900Here’s a shot of top open and zipped — Looked for a label — none found —July 1, 2013 at 1:09 pm #256901Anonymous
InactiveJack: That looks like my old top. Tag could not be seen untill seams were taken apart. It was hidden well. In sleeve for metal top bow.
Your car looks nice.July 2, 2013 at 8:25 am #256902Thanks George. My seams on the top bow pockets are starting to come loose — it will soon be time for the top to go to the canvas shop to be re-sewn. I’ll ask them to look for a tag. I also like Billinparts idea of having some clear quarter panels put in — this top has a pretty big blind spot as designed.
The car is coming along — the pic’s do not show the missing dash (being sanded, stained, and sealed) and dangling wires — and new hole cut in the dash to raise up the steering column — but that’s a story for another post.July 2, 2013 at 7:52 pm #256903I’m jealous of the zip-in rear window. Must make the top-up ride very nice and breezy.
July 2, 2013 at 8:00 pm #256904Roy,
Its odd that the MiGi rear window is sewn in and the asembly manual for the MiGi II shows it as a zipper open and close like Happyjack’s photos. Things that make you go hmm……………….Allen Caron
"If one thing matters, everything matters" - from the book The ShackJuly 2, 2013 at 9:18 pm #256905Allen, Not really so odd. My TDr is a Daytona MiGi. Jack’s car is a Fiberfab MiGi II. The info that I have is that Daytona sold their molds to Fiberfab. Fiberfab’s early TDr was very similar to Daytona’s due to the fact that they were just assembling and selling old Daytona parts. Eventually Fiberfab made some changes to the molds and their TDr morphed into a MiGi II. Looking closely at the two cars (Jack’s and Mine) reveal quite a few differences. Even though they may have shared a fiberglass mold, the MiGi II appears to be a heavier build. Jack’s top looks like it is a reaqlly nice luxurious Sunbrella fabric. Mine is just a common, run of the mill typical canvas top material found on all convertible cars of the 50-70’s.
July 12, 2013 at 4:19 pm #256906I have been looking into a new top myself.One of the top builders suggested a oval rear window.I have never seen an oval rear window on a TD replica or any other car but it would look nice and it would zip out easily.
July 12, 2013 at 4:30 pm #256907Oval on a MGTDr. Sorry, but my opinion is: Yuk! The heavy duty zippers necessary for out tops really don’t like going around bends unless they are very gentle. I don’t think that the clear part would be without some serious wrinkles. Why not look into a roll up top like was recently discussed here. Happy Jack posted some pictures.
July 12, 2013 at 5:57 pm #256908Visibility is bad enough with the tops up without the limited view through an even smaller opening.
"Drive Happy"July 12, 2013 at 8:54 pm #256909If you want to see an oval window, look at a 56 VW Beetle. That was the last year of the oval window. Wouldn’t want an oval window on the TD. Now rear side windows would be nice!
