Home › Forums › General Discussion › Dash Switches
- This topic has 11 replies, 6 voices, and was last updated 15 years, 2 months ago by
Dan Rosa.
January 23, 2011 at 10:42 am #233326
Just a word about the new switches in my Dash in case anyone needs a good replacement switch that matches the original kit ones. I needed two more switches for my dash and found exact matches at Pepboys. I mean they were identical.
"If one thing matters, everything matters" - from the book The ShackJanuary 23, 2011 at 3:17 pm #243468Would you have a part number for these switches? There are no Pepboy stores close by and I could not locate any on their website.
January 24, 2011 at 6:53 am #243469Paul,
The only part number I can find for the switch I purchased is on the carton. But that part number is: 86914 abd it’s a Brass, 3-position, Push/Pull switch with 4 terminals. I pland on using it for the Emergency Flasher. Hope this helps.
"If one thing matters, everything matters" - from the book The ShackJanuary 24, 2011 at 7:22 am #243470Number didn’t work, but I thank you for the reply.
January 24, 2011 at 9:04 am #243471I’m betting you’ll find a match here:
I simple Googled “push pull switch”. But seeing the results on ebay motors, I am reminded once again that marine suppliers are often the BEST source of miscellaneous bits and pieces for our TD replicas!
PMOSSBERG40567.3792824074
January 24, 2011 at 11:53 am #243472Thanks Paul. I should be able to find what I need.
January 24, 2011 at 11:41 pm #243473Paul is on the mark as usual
DanJanuary 25, 2011 at 9:52 am #243474Aw shucks.
Thanks Dan!
January 25, 2011 at 11:06 am #243475Paul is just a wealth of unmarketable knowledge…like most car nuts!
January 25, 2011 at 1:49 pm #243476Yeah, it would be nice to be able to make money off this stuff wouldn’t it?
January 25, 2011 at 2:42 pm #243477Make money? I must have it backward! My money tends to flow in the other direction.
January 25, 2011 at 3:22 pm #243478We can all make money but,, it will cost time just like oil , 10
20 Dan -
