Home › Forums › General Discussion › Daytona migi needs new gauges or old fixed
- This topic has 15 replies, 5 voices, and was last updated 1 year, 5 months ago by
Robert.
September 1, 2024 at 10:45 pm #309052
I’m running out of places to get my gauges fixed I have set of vdo id like to keep all the old ones but be willing to consider some old looking new ones that don’t brack the bank
September 1, 2024 at 10:48 pm #309053Also any tips on owning a tdr and making driveable I’ve done a lot to get it to this point but any tips help in case I over looked something
September 2, 2024 at 8:04 am #309054I have a set of VDO Vintage gauges that I removed several years ago. They were the “Vintage” series. What are you in need of?
"Drive Happy"September 2, 2024 at 2:13 pm #309055I for sure need a tachometer what color are your faces maybe interested in whole set
September 4, 2024 at 8:28 am #309058I’ve searched through the black hole that is my garage and the only tachometer I found was a Stewart Warner unit. Odd, because I removed VDO from the car and installed Stewart Warner. Sorry, I can’t help you.
"Drive Happy"September 5, 2024 at 4:51 pm #309060I might have some in a box someplace. Need Tach only? What type? Please post a picture if you can or PM me. I think these are the white faced ” Vintage ” gauges that many cars came in – SS or Chrome rings I think. I bought the kit to replace the speedo but got the original to work but might keep that one.
September 5, 2024 at 7:41 pm #309062Id be interested in any thing you have call or text me 218-731-6832
September 5, 2024 at 10:09 pm #309063What is wrong with your gages? Are you talking the speedometer and the tach? If the Speedo doesntwork I may be able to help you. I just fixed mine. Do not try to remove the bezel by prying it off. You will destroy it.
September 5, 2024 at 10:17 pm #309064My tachometer don’t work and few others I don’t have endless money to put into it so was going to get fixed one at a time but I’m open to getting gauges to put in for the time being till I come up with the 385 to get mine tachometer fixed
September 5, 2024 at 10:18 pm #309065The speedometer never been hooked up but it’s on my list to do
September 5, 2024 at 10:20 pm #309066Id even like if I could find one just like it
September 6, 2024 at 4:34 am #309067The speedometer never been hooked up but it’s on my list to do
You say you have other gages not working so it may be a electrical problem. I purchased my MIGI two months ago and at the time, the low beam lights did not work. After a lot of troubleshooting I found the problem. On mine under the dash on the drivers side I have a strip with all the glass fuses. The one for my low beam headlight had some corrosion between the tips of the fuse and the holder. Could not see it with the naked eye. Removing and reinstalling the fuse 2 or 3 times made good contact again and now my lights work.
You should remove each fuse one at a time and clean the ends of the fuses and the holder with a fine sandpaper or steel wool. You may get luckySeptember 6, 2024 at 12:11 pm #309072Robert
I will give you a call later today. I need to have my wife dig them out – recovering from a broken back.
September 6, 2024 at 5:39 pm #309073Broken back is no joke you can take your time I am not in desperate need I did pull mine out and bench tested it
September 11, 2024 at 3:27 pm #309083I have a set of
<h1 class=”a-size-small a-color-secondary a-text-normal” data-feature-name=”title” data-template-name=”title”><span id=”title” class=”a-size-small”>MOTOR METER RACING Classic 6 Gauge Set with GPS Electrical Speedometer Digital Odometer Beige Dial Black Needle Light Bulb Illumination 85mm 3-3/8″ & 52mm 2-1/16″ gauges coming from amazon. Ill let ya know how they work out.</span></h1>September 11, 2024 at 8:51 pm #309084I’m open to any input because if I dont use them on this I’ll need some for my bricklin gt or my buggy for the buggy only going to do speedometer with fuel gage and oil pressure and maybe volt meter and a tachometer but this tdr is my baby of them all so it’s getting the most love
