Home › Forums › MGTD Kit Cars › VW Based Kits › Dim Headlights
- This topic has 6 replies, 5 voices, and was last updated 12 years, 2 months ago by
December 25, 2013 at 2:34 pm #235026
The headlights on my TDr are not very bright in the normal mode. They are Lucas headlights and are wired correctly with a good solid ground. Is this normal? or do I need to switch them out for brighter ones? I hesitate to drive at night with them not throwing a decent beam on the road.
Mike Neben
December 25, 2013 at 3:56 pm #259208Update to my previous post. They are not Lucas, they are Dietz headlights. But they’re still dim.
Here’s a photo taken todayDecember 25, 2013 at 7:26 pm #259209Do they have a relay in the circuit? If not, consider adding one for each circuit (dim and bright), with the positive side fed directly from the battery with a large enough gauge wire. Locate them closer to the headlights, so there’s as little current drop as possible.
Then, the current circuit through the switches just controls the on/off and dim/bright switch functions, while the new heavier-gauge circuit provides the power for the lights themselves…Early FF TDr on 69 VW pan
Slowly coming back from the ashes...December 25, 2013 at 8:49 pm #259210Also re-do your grounds. And if that doesn’t get it, get new bulbs.
December 26, 2013 at 10:35 am #259211And to think every car on the road used to have those same “dim” sealed beam headlamps.
And we thought they were bright.Paul Mossberg
December 26, 2013 at 11:31 am #259212Paul’s right.
December 26, 2013 at 4:39 pm #259213And Mike, Im betting it is only the headlght buckets that are Dietz, right? You have plain old sealed beams inside.
Another option…replace the sealed beams with halogens:Paul Mossberg
