Home › Forums › MGTD Kit Cars › VW Based Kits › e brake handle
- This topic has 17 replies, 8 voices, and was last updated 14 years, 4 months ago by
Anonymous.
April 16, 2011 at 9:06 pm #233435
I saw a pic of a car with the e brake handle standing up rather than lying down. It seems a great way to get access to an e brake so far forward. Anyone else know about this?
Thanks,
Pat
April 16, 2011 at 9:25 pm #244308Pat, The only VW based car I have seen with the E-brake handle any where close to vertical is the London Roadster and only the ones built on their custom pan.
Classic Roadster Duchess,which uses a bench seat gave instructions in the assembly manual how to modify the handle to be at an angle of about 30 degrees from the floor. You may be able to find it in the download manuals section.
I modified the e-brake handle in my London Roadster on a VW pan by cutting a V section in the handle and welding it back together.Not exactly perfect but a big improvement.
See Edsnova’s post for a step by step story on moving the handle to a position between the seats.
April 16, 2011 at 10:01 pm #244309If I can do it anyone can.
Here’s the original thread with Washington Will’s effort as well. He’s the pioneer on this.
edsnova40650.3682407407April 16, 2011 at 11:51 pm #244310Hi Pat,
Before you drive yourself crazy looking for them…the Classic Roadsters manual does not have instructions on moving the e-brake handle to an upright position.
It’s a bit of a stretch, but I can reach mine easily, with the e-brake in its original position.
If you choose to do so, modifying it is pretty straight forward. You cut the bracket free from the chassis tunnel, bend it up and weld in triangles of steel to fill the gap caused when you bend it up.
PMOSSBERG40650.0133101852
April 17, 2011 at 8:51 am #244311bump
April 17, 2011 at 9:42 pm #244312The MP Lafer’s also have a vertical handbrake. If I recall correctly their
modification is only to the handle itself by repositioning the “ratchet” gear
and by adding a couple of tabs to attach the brake
cables17_214221_hand_brake_2.jpg”>04-17_214253_hand_brake1.j pg”>
April 17, 2011 at 9:52 pm #244313calafer,
thanks for the pictures they are inspireing.
April 17, 2011 at 10:01 pm #244314Sorry , forgot to resize original photos…
April 17, 2011 at 10:03 pm #244315
April 17, 2011 at 10:13 pm #244316Very clean job.
April 18, 2011 at 8:41 am #244317Really nice work Calafer!
Like the disc brake front end too!
April 18, 2011 at 9:06 am #244318Great job Calafer! Those pictures were worth 1000 words. Do all the MP Lafers have the master cylinder relocated near the pedal assembly or is this your personal design? Also ,are the body and fenders molded in one piece?
April 18, 2011 at 5:13 pm #244319Wow – that pan looks new – I wish mine looked like that when I started
April 19, 2011 at 12:55 am #244320Thanks for the positive comments on the pan!! Several years ago I bought a
fairly beat up but as it turned out, very complete, Lafer on ebay because my sons
wanted to rebuild a car. Their interest lasted about 3 days but I was hooked and
after a few weeks of indecision decided to rebuild it from the ground up. Thus I
ended up with probably hundreds of pictures of all aspects of the car.
In regard to the questions of the pan I ended up installing new disk brakes on all
4 wheels along with new master cylinder and brake lines. I believe all MP Lafers
have the master cylinder located on the pedal assembly bracket while the brake
fluid reservoir itself is located in a more convenient location in the front trunk
area connected to the master cylinder via a hose.
As far as the body is concerned it is a one piece fiberglass unit with both the
front and rear fenders already attached.
Here are a couple of additional pictures of the Lafer brake handle, I hope they
help..
April 22, 2011 at 8:13 am #244321Hi folks,
If you are looking for the disc brake conversion discussion that began under this “e brake” thread, I moved those posts to a new thread titled “Disk Brake Conversion”:
https://tdreplica.com/forum/forum_posts.asp?TID=1502& PN=1
If you are starting a new topic, please start a new thread.
Remember, we are building an historical library of very useful info here. To have the disc brake discussion under the “e-brake” subject would make it difficult to find for those that come after us.
April 22, 2011 at 9:36 am #244322Calafer,
Did you do the e-brake handle mod yourself? Was it difficult moding the ratchet portion of the ebrake handle? The two cable brackets seem easy enough to handle?Allen Caron
"If one thing matters, everything matters" - from the book The ShackApril 23, 2011 at 3:03 am #244323No, I didn’t do any modifications, I assume its the standard Lafer design. I
believe that the only modification to the handle are the cable brackets. On
the chassis there is a hardened steel gear rack ( like a section of gear) that
needs to be rotated about 40-50 degrees in such a way that the ratchet
tooth already existing inside the brake handle (this ratchet tooth is
connected to the button you push to release the hand brake) meshes with
the gear rack when the handle is in the near vertical position (hence the 40-
50 degree rotation) . In my car the hardened steel gear rack was removable
(1968 chassis) but I’m not sure if this is true of all VW chassis.
December 2, 2011 at 7:18 pm #244324Anonymous
InactiveThe transporter parking brake looks like it could be adapted to our cars. I think I will look around the yards for one.
