Home › Forums › MGTD Kit Cars › Non MGTD Kit Cars › electronic Ignition Recommendations
- This topic has 4 replies, 4 voices, and was last updated 10 years, 11 months ago by
December 14, 2014 at 1:27 pm #235504
Guess I’m putting together my Christmas list. I have always used points and condenser for all my VW ignition systems. Going to enter the 21st century and get electronic ignition. Compufire, Petronix or some other brand. Any recommendations on which will serve me the best. Running stock 1600 dual port with SVDA and 34PICT3 carb.
Thanks and Merry Christmas y’all! 🙂
"If one thing matters, everything matters" - from the book The ShackDecember 14, 2014 at 1:35 pm #262407Can’t recommend a whole distributor — you may want to consider just trying to find a points replacement module to replace the points in your original factory distributor.
Though I have a Pertronix SVDA sitting here, unopened, I’m a bit reluctant to even try it until after significant road-testing. (I’m currently running an aftermarket 009 with electronic module on the 1679cc.) There’s a lot of discussion on Samba about problems with the Pertronix vacuum advance/retard not working correctly, especially with duals. I have the additional challenge that with dual carbs, I have less vacuum and the potential of vacuum pulses…
So, I’m waiting until farther down the road to mess with it…
Slowly coming back from the ashes...December 14, 2014 at 7:07 pm #262408So far I’ve had good results with pertronix, first one was a drop in replacement for an 009 and then I got a complete distributor with SVDA. Just make sure you get the right model replacement for use with the vacuum advance.
December 14, 2014 at 8:42 pm #262409Wow! Thanks guys. Didn’t know there was a requirement for SVDA or mechanical distributors. Great info. I’ll have to check them out.
"If one thing matters, everything matters" - from the book The ShackDecember 14, 2014 at 8:47 pm #262410I ran a petronix module in Bridget, which had an SVDA and a 34 PICT 3 like yours. Worked perfectly once I turned the thing to correct timing. I had set it static with points and the Petronix system required me to turn the disty about 25 degrees for the same timing. I ended up using a timing light to get it to 28 degrees before TDC at 3000 rpm. About a month after I put it in the coil failed. Turned out to be unrelated. Put a new one in and never messed with it after that, 2-3 whole seasons.
All that said, I did keep a complete spare disty under the driver’s seat, rigged with points, condenser and a good cap, just in case. -
