Home › Forums › MGTD Kit Cars › VW Based Kits › Emergency Flasher Relay
- This topic has 5 replies, 5 voices, and was last updated 9 years, 10 months ago by
scubasteve.
May 13, 2016 at 3:09 pm #236125
Who has the Emergency Flasher Relay in their VW based TDr? How did you wire it in?
"If one thing matters, everything matters" - from the book The ShackMay 13, 2016 at 6:27 pm #268075I do, but I can’t really help you. I didn’t wire it, and mine appears to use the whole ’69 donor harness… At least for now. Will totally rewire it when I upgrade the dash.KentT2016-05-13 18:30:03
Slowly coming back from the ashes...May 13, 2016 at 6:35 pm #268076The easiest way is to find a hot wire that goes to the left two blinkers and also a wire that goes to the right two. Then, attach one wire to one pole of a spst (simple on/off switch) and the other wire to the other terminal of the switch.
Now when you have the new switch off, nothing is changed.
When you turn your new (hazard/emergency) switch and put your turn signal in either position (right or left) all 4 corners will flash. They will flash at a different rate than your normal turn signals, but so what??
May 13, 2016 at 7:52 pm #268077I updated the electrical drawings from a FF and added relays for the headlights, fogs, blower and windshield wiper motor. As there were no hazard/4 way circuit I added it to the drawing. I have sent the drawings to a couple of members. If you can use the drawings let me know and I can send the .pdf fileToller2016-05-14 08:55:02
David B Dixon
SabineMay 13, 2016 at 11:24 pm #268078David. Sent you a PM,
"If one thing matters, everything matters" - from the book The ShackMay 14, 2016 at 11:24 am #268079Royal wrote:The easiest way is to find a hot wire that goes to the left two blinkers and also a wire that goes to the right two. Then, attach one wire to one pole of a spst (simple on/off switch) and the other wire to the other terminal of the switch.
Thanks for the tip. I’m going to give it a try.
Unable to find my hazards, I resorted to using 2 bicycle flashers when I needed to tow my LR. They did the trick, letting others know there was an issue, but NOT the best solution!
I have found several switches on the dash that don’t seem to do anything. I think the previous owner(s) may have gotten “creative”…Amor Conquista Todo
