Home › Forums › MGTD Kit Cars › VW Based Kits › engine niose
- This topic has 8 replies, 5 voices, and was last updated 14 years, 1 month ago by
February 18, 2012 at 11:50 pm #233993
I am finaly driving the car after rebuild but the engine niose inside the car is very loud. ant ideas or is this normal?
ThanksFebruary 19, 2012 at 9:27 am #249306Mystic,
VW or front engine?
February 19, 2012 at 9:52 am #249307VW daytona migi with single pull down engine cover.
February 19, 2012 at 10:03 am #249308I would upload a picture but cannot seem to do so.
February 19, 2012 at 10:28 am #249309With a VW based TD you are sitting where the rear seat used to be. There is very little room between you and the engine…about 18 inches. There isn’t much you can do to keep down the noise. I’ve read here that adding heat insulation in the engine compartment area helps some but other than that…..ear plugs.
"If one thing matters, everything matters" - from the book The ShackFebruary 19, 2012 at 11:50 am #249310Top down and Ear plugs and a hoodie helps
February 19, 2012 at 12:37 pm #249311Mystic,
Like they said…
YES. The engine noise is normal! No soundproofing, and you are sitting a couple feet in front of an air-cooled engine.
February 19, 2012 at 5:44 pm #249312My car seems louder with the top up than down. Either the space is more confined as is the noise, or else in the open air the wind noise blocks it out.
Get ear plugs if it bothers you, and it will also save your hearing!, and you will be less fatigued, especially on a long tripFebruary 19, 2012 at 6:44 pm #249313Same for me mrlmd
I think the top acts sort of like a megaphone, focusing the engine noise.
There was another VW engine noise discussion in this thread:
https://tdreplica.com/forums/topic/engine-noise/#post-247845
