Engine tin for my TD
Home Forums MGTD Kit Cars VW Based Kits Engine tin for my TD
  • #232294
    Dale Schumacher
    @schu
    Guys I need a little help
    I have been using a temp foil type tin to keep the heat away from my engine compartment, but have noticed it is starting to get sucked into the fan intake ( not a good thing! )
    I will be replacing all the foil insulation w/ tin, but am asking if anyone has any patterns for a Fiberfab TD? I have all the VW tin now, but need to close the whole area between the VW tin and the fibergass body in front and the bumper support in the rear. Does anyone have any patterns or do I need to work it all out w/ cardboard and transfer it to the tin.
    Let me know if you can help,
    Dale
    #237078
    Phil
    @phil
    You are probably best to make your own patterns out of cardboard.  They are not that hard to make.  I doubt that mine are still around.  We have just moved and there is only a slight chance that they are tucked in a corner somewhere.
    Phil
    #237079
    Dale Schumacher
    @schu
    Thanks Phil
    If you find them let me know – otherwise I guess I will try to make my own patterns.
    Anybody else done this yet?
  • The topic ‘Engine tin for my TD’ is closed to new replies.
