Home › Forums › MGTD Kit Cars › VW Based Kits › Expanding the passenger footwell
- This topic has 12 replies, 4 voices, and was last updated 10 years, 8 months ago by
John Black.
July 24, 2015 at 12:22 am #235813
Hi Guys,
Number one peeve for the good lady is the fact that the passenger footwell is so small and tends to tilt the feet backwards. I have toyed with the idea of removing the end of the footwell as it stands right now just to see! As far as I could tell there was nothing behind the panel and this proved to be the case. I made three cuts to it with a cutting disc on my 4″ angle grinder. Once the panel was removed this exposed a huge void, just an empty compartment. I intend to fold up an alloy box shaped panel to fit into the void and give the area some structural rigidity. I may even glass over it too, but that’s yet to be seen.
I will try to post the pictures as I complete the task. Some of you may remember that I only had the cast taken off my broken hand a few days ago and todays workout did a bit of a number on it, so I may have to rest it before I complete the rest of the work.
John the Brit.
July 24, 2015 at 1:25 am #265246Anonymous
InactiveJohn: Previous owner of my FF made a glove box? ,In that space . It is about 24 inches deep. Quite hidden if you don’t know were it is. It is a pain to get into it. Have to open passengers door and be outside the car to see what is inside. Good space for little used items like a pair of coveralls, jack and spare tools and parts.
July 24, 2015 at 10:38 am #265247Nice idea!
I have a gas tank on the floor ahead of the passenger side “firewall”Paul Mossberg
July 24, 2015 at 11:23 am #265248Hi Paul,
I think you have mentioned your gas tank placement in the past. I am; for now anyway happy with the gas tank size. The leg room was becoming more of an issue with the other half. These are the during construction pictures. Very simple task of cutting the fibreglass section, the most effort will be in the folding of the new box to make it into a footwell again. I will also have to reroute a few ground wires.
Its all good fun anyway.
John the Brit.
July 28, 2015 at 11:27 am #265249Hi Guys
Well the new footwell is a resounding success in that the passenger now has some room for his or her feet. The sheet aluminum box was fairly easy to fold up even without a box and pan folder. I merely used two pieces of 4×2 as the folder. The box you have to make is 10″ from top to bottom with 12″ square sides. The box must narrow to 10″ at the bottom to accommodate the body structure shape on the right hand side. That sounds more complicated than it actually is. The only other work I had to do was to move a ground connection that I found behind the panel that I cut out.
July 28, 2015 at 12:39 pm #265250Nice!
July 28, 2015 at 3:09 pm #265251Good work!
Befoer you do the finish work, like carpet, do you have some pics of the final creation?Paul Mossberg
July 28, 2015 at 3:16 pm #265252Hi Paul
I was trying to post more pics with no success. I shall try again shortly.
John
July 28, 2015 at 3:24 pm #265253Hi Paul its still not cooperating. The Error message states “Error inserting object in current location” the pic is 42kb so I think it should fit. Help?
Thanks John
July 28, 2015 at 5:58 pm #265254Sigh.
We’ve had picture problems before. Not sure it will matter, but what device are you acceessing the site with?Paul Mossberg
July 28, 2015 at 7:55 pm #265255Hi Paul,
Im using a laptop pc. It loaded the previous picture fine, I have tried the others using the same method with no luck, I shall keep on playing with it as time allows.
Thanks
John
July 28, 2015 at 8:10 pm #265256I’ve got that error before. When I got it, what worked was to go back to the picture select part of the process, find the photo in my big pile of photos already uploaded here, and select it again. That has worked for me every time.
Still not sure the source of the error tho.July 28, 2015 at 8:21 pm #265257Hi Ed. Thanks for the heads up. I will try to do that later.
John
