Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › fiberfab body
- This topic has 6 replies, 4 voices, and was last updated 15 years, 1 month ago by
ray10.
February 6, 2011 at 8:42 pm #233348
Hi. I have a 1953 classic kit. I’m having trouble getting the battery box to meet up with the floor pan ,this is on a chevy frame ,I’m woundering if there needs to be a spacer put under the body to raise it up to match the battery box ?
TDREPLICA Map
February 6, 2011 at 10:49 pm #243668Ray OK ,,,this post answered my question under the general post . As your question ..mine also a chevy powered kit ,the frame is not chevy . but is built by F/F . keep the body as low as you can to the battery box if I was to do that part on my car I would keep it all low .. I would lower the B/box mine was all glassed in when I got her she is 3 inches to tall in the front
check the manuals the left of the home page Dan February 7, 2011 at 12:33 pm #243669Dan R is correct. None of these front engine/RWD TD Replica’s are on an OEM manufacturer’s frame. Both the Pinto/Mustang II and Chevette/Pontiac T-1000 were Uni-body cars and had no frames.
The frames for these replica’s were all provided by the kit manufacturers, Classic Motor Carriage/FiberFab, Classic Roadsters Ltd, British Coach Works, etc. they are usually made using .090″-.125″ thick walled recatangular, mild steel, seamed tubing (cheap). Most were jig made by sub-contractors to the kit manufacturer’s specs.
The frames were purpose built for the TD’s to use the drivetrain (engine/trans/rear) and suspension from the “donor” car. In some cases, the fuel tank, driveshaft, wiring harness, radiator and some other donor car parts were used to.
So, when people say “my TD is on a Chevy or Ford frame” they are incorrect. It’s a purpose built frame using the Ford/Chevy donor parts or kit supplied parts that make up a rolling chassis for the TD replica body to sit on.
February 7, 2011 at 4:57 pm #243670Ok, So I need to cut the frame work for the battery box down to match the two panels . this might help me with the steering wheel because it seams a little to high.
TDREPLICA Map
February 7, 2011 at 6:21 pm #243671If you are referring to the metal frame work that the fiberglass panels attach to ,I would be very cautious . The fiber glass panels may not be in proper position.,The steering column can be lowered by making a bracket if necessary. Unless the frame was built to the wrong measurments,something else may be wrong.
February 7, 2011 at 7:19 pm #243672Any chance one of you might have that measurement, so I can double check what I have. I’m only a 1 1/4 short.
TDREPLICA Map
February 21, 2011 at 11:36 pm #243673Hi, Can any one give me a picture of the drivers side where the pan meets the battery box .I can’t get the two to match up.
thanks
TDREPLICA Map
