Home › Forums › MGTD Kit Cars › VW Based Kits › Floor Pans
- This topic has 8 replies, 5 voices, and was last updated 10 years, 2 months ago by
November 22, 2015 at 9:06 pm #235942
Hi everyone, thanks for all the great help so far.
I pulled the carpet out tonight and found rust has taken over so much so that I can put a screwdriver right through the floor. I read a few posts on floor pans but I am still confused. My seats sit on a box meaning I have no seat rails. Any suggestions on where I can get replacement floor pans? Is this an easy job? Are they welded into place? Is it plug and play in terms of fit?November 22, 2015 at 9:18 pm #266354Jordan,
Done properly, it’s a weld in procedure. You can also rivet them in and seal the seams, it’s just not as good a fit.
There are many sources. This is just one..which also includes a DVD with the installation procedure. Scroll down, the floor pans are about half way down the search results:
http://www2.cip1.com/SearchResults.asp?search=floor+pans&Submit=
PMOSSBERG2015-11-22 21:19:49
December 1, 2015 at 11:47 am #266355Do you need to take the body off before installing the pans?
December 1, 2015 at 1:11 pm #266356Sorry to say the answer is yes the body will have to be removed. This is because the floor pans come a standard size and will need to be trimmed to fit the individual VW pan. Each pan is slightly different.
"If one thing matters, everything matters" - from the book The ShackDecember 4, 2015 at 11:17 am #266357here we go!!
December 4, 2015 at 11:55 am #266358Good luck!
December 4, 2015 at 2:38 pm #266359Post pics, please.
December 6, 2015 at 6:36 pm #266360I replaced my floor pans but it took awhile to complete my project, as I did a complete frame, engine, body, and new dash wiring, Complete restoration. I built a in garage hoist out of 4×4 timbers, with 1×2 angle support arms. I used a Cable Come a Long from Harbor Freight Tools, to lift the body off. I have some great pics to share, but my iPad will not up load any pictures. You can save lots of money by doing it yourself. Please contact me via site IM, or my private email davearoy@yahoo.com. I will be glad to answer any questions you may have. Be especially careful of marking the front Napolanes Hat support, weld to frame spot and where the rear pan supports weld to the frame. My weld in new pans were 1/2 inch off, which made it a challenge to replace the body back on the chassis. Use a professional Welder, as the pan sheet metal is very thin, and needs good support welds. Also DO NO CUT OFF old pan material, any closer then 1/2 ” to the support center, as you need to lay the inner edge of the pan on top of this 1/2″ flange.
Good Luck with it ……….. Send me ur questions!
Dave
Dave
Lakeland, Florida, where we drive Topless every dayDecember 6, 2015 at 7:49 pm #266361Great info, Dave. Thanks!
