Home › Forums › General Discussion › ford emblem
- This topic has 5 replies, 3 voices, and was last updated 10 years, 5 months ago by
November 4, 2015 at 11:46 am #235915
For some reason someone put a ford emblem on the passenger side and on the back of my London roadster. I plan on removing them this winter. Then buffing out the paint and touching up any scratches. Will upload pictures when I can.
November 4, 2015 at 11:50 am #266145You might want to make sure it’s paint and not gelcoat. The process is different..
November 5, 2015 at 10:41 pm #266146The Ford emblem is a raised stick on. I need to find out how to up load a picture of it.
November 6, 2015 at 8:52 am #266147Hit it with a hair dryer or heat gun (careful with the latter, they can get very hot). After it warms up, keep the hot air flowing, while slowly lifting one edge. It should start to release. And any residue can be cleaned up with something like Goo-b-gone. WD-40 can clean up sticky stuff too. A little wax and you’re done.
November 7, 2015 at 1:44 am #266148Thanks, the hair dryer is a great idea. That’s why I love this sight. It saves me time and money when working on my car. Plus I get to meet a lot of new people.
November 7, 2015 at 8:58 am #266149If it feels like it does not want to let go…
You can use fishing line as a “saw.” Slip it between the emblem and the car and sort of saw through the foam. The line is strong enough to cut the foam, but will not scratch the paint/gel coat.
You’ll be left with the old foam on the car, but that just means a little more elbow grease on final clean-up.
Dental floss works too, and leaves your car smelling minty fresh! 😆
PMOSSBERG2015-11-07 09:10:17
