Home › Forums › MGTD Kit Cars › VW Based Kits › Found a car
- This topic has 7 replies, 5 voices, and was last updated 14 years, 9 months ago by
June 11, 2011 at 8:11 am #233507
Well I found a car locally which needs some fixer-upper stuff done to it, and my first question (probably out of many more to come), is what do you use, spray adhesive, contact adhesive, to glue down the carpet liner to the firewall and floor? Is there something you get in a spray can and coat it all then just stick it down, or is it more involved than that?
Thanks.June 11, 2011 at 8:27 am #245088I used a 3M version of this product to bond a liner to a fiberglass hood. It’s been hanging over a smallblock V8 for 15 years with no separation. You can find it on the shelf at your local parts store. Or, you can start an account at Eastwood.
Eastwood Carpet and General Purpose Spray Adhesive 14 oz net Aerosol
Item #12743 Z @ $6.99
http://www.eastwood.com/ew-carpet-and-gp-adhesive-14-oz-net- aerosol.html
June 11, 2011 at 9:57 am #245089I used 3M “Fast Tack”. (following Classic Roadsters Ltd.’s recommendation)
http://www.3m.com/product/information/Fast-Tack-Trim-Adhesiv e.html
Lots of on-line resources if you cannot find it locally
PMOSSBERG40705.4151736111
June 11, 2011 at 10:45 am #245090After a coffee or two and general discussion I used fast Tack
June 11, 2011 at 11:47 am #245091Thanks, I’ll check with the local auto supply store to see what’s available, online probably will be half price the way things are down here. That’ll be one project down, who knows how many more to come.
June 11, 2011 at 1:52 pm #245092The 3M-90 carpet spray adhesive is like $20 in my local auto supply place for the big can. Works good, but Eastwood sounds like the better deal for sure.
June 11, 2011 at 4:29 pm #245093There are two levels of adhesive. One for carpets, the other for hood liners, head liners and trim. The trim adhesive is much stronger stuff. The standard Eastwood product is $6.99 on sale, $12.99 retail. The Eastwood super stick stuff goes for $18.99. I used 3M trim adhesive on my Avanti hood.
After shipping, the $6.99 Eastwood product might cost almost as much as the local trim adhesive.
June 11, 2011 at 8:18 pm #245094For what it’s worth, I used the 3M Fast Tack on everything. Welting, interior panels, carpet…you name it.
I built my car in 1982. Nothing has fallen off. And the only thing that had to be reglued was a small portion of carpet in the trunk that was glued to bare plywood.
