front disc brake’s
Home Forums MGTD Kit Cars VW Based Kits front disc brake’s
  • #233595
    Richard Shear
    @gbidick
    I have ATE caliper’s and need new brake pad’s. Don’t know what year of caliper or what model it came from. Can anyone help on what pad’s to order ?
    Thanks,
    Dick
    #245675
    Larry Murphy
    @larry-murphy
     Dick, With your special suspension,I’m not sure if they used VW brakes or something from the aftermarket . I searched ATE Brakes on the web and found numerous sources ,so they must still be in business.Gook luck finding the type for your car.You may have to take them off and match something up.
    #245676
    How do those calipers taste?
    #245677
    There’s that valuable input we have come to rely on!
    Thanks Ed!
    #245678
    Richard Shear
    @gbidick
    So far I have found out that there are only 2 different ATE caliper’s that VW used that are 2 pin. One takes a 60mm pad the other takes a 55mm pad. (width) I take the 55mm. Getting close now.
    #245679
    newkitman
    @newkitman
    Try airhead parts for the calipers. The calipers on my 74 Ghia are the same (2 pin – 55mm pads). I got mine from them when they were just Karmann Ghia Parts and Restorations. Good, high qualiter parts.
    #245680
    Richard Shear
    @gbidick
    I think the mystery is solved. 1966-1971 squareback
    Got the new pads on order.
    Thanks for all your help everyone.
    Dick
