Gel coat or fiberglass cracking?
Home Forums General Discussion Gel coat or fiberglass cracking?
  • #233667
    MGLondonRoadste
    @mglondonroadste
    There are several areas on my car body that show signs of cracking around fittings, like bolt heads. Can this be repaired so that it can be smooth again?
    #246303
    It is likely the cracking is happening in the fiberglass and not just the gel coat. So…
    Any repair is going to be a tough job, potentially patching the fiberglass and repainting.
    #246304
    newkitman
    @newkitman
    Repair might call for removing a part (like a fender), sanding, fiberglass repair, painting and installing the part. When you get the part repaired and if a washer is called for make certain to install it and not overtighten the bolts and nuts.
    #246305
    MGLondonRoadste
    @mglondonroadste
    Thanks guys.   I won’t have time for doing this work myself.  I just started a new job and it has long hours each day leaving no time during the week.  I’ll have to find a fiberglass repair shop and make a weekend appointment.
