Home › Forums › General Discussion › Gel – Coat Wax?
- This topic has 27 replies, 12 voices, and was last updated 12 years, 4 months ago by
BEBOP.
November 20, 2013 at 1:20 pm #258632
Little circles, big circles. Kent, you’re a more patient man than me.
November 20, 2013 at 1:57 pm #258633edsnova wrote:Little circles, big circles. Kent, you’re a more patient man than me.I tried an orbital briefly, and didn’t like the job it was doing on the curved areas (fenders especially), and there’s really very little flat area on these things to use one. I found I was having to do most of it by hand any way. So, I quickly just set it aside and went with hand pads…I’ve used compounding as “therapy” to keep me motivated to keep fighting the PITA rusty brake system and worn components.1. Originally planned replacing only the flexible brake lines only to find rust inside everywhere, and had to replace metal lines also. Similarly found a bad tie rod end to replace only to discover the tie rod itself was bent – so now it has all new tie rods and ends. Had to use angle grinder to cut the nuts/threads off two tie rod ends and borrow a “tuning fork” to break the other ends loose after that. Even with repeated use of Kroil and PBblaster, I’m twisting off bolt heads, etc. This thing had been parked inside a barn since 1998 — but it must’ve been a very damp barn!2. Similarly, found the original steering stabilizer was so worn you could play it like a trombone, so I replaced it — and the front shocks.Bottom line is that everything so far has taken about 3-4 times the amount of time/effort I’d originally thought, so I’m just using it a the hobby project that it should be, taking my time a little at a time….Early FF TDr on 69 VW pan
Slowly coming back from the ashes...November 20, 2013 at 4:17 pm #258634Well, I agree that you have to be super carefull with electric buffers or polishers with Fiberglass and gel-coat. The heat builds up fast if you are not carefull. I had one of those orbital buffers and mounted it upside down inside a five gallon plastic bucket, lined the inside of the bucket with sheepskin, and turned it into a great pool / billiard ball polisher. With a little Aramith Billiard Ball Cleaner it buffs an entire set of pool / snooker balls to a brilliant shine in about three minutes. Thats about all high speed buffers are good for in my view.
